Z CAM SSP Source 0.13.0
xm1994 updated obs-ssp with a new update entry:
obs-ssp 0.9.0 released
[beta] obs-ssp 0.9.0
A huge upgrade prior to 0.1.0
Features:
  • ZCAM ssp camera as OBS source directly!
  • Tiny latency (about 100ms).
  • (New) Auto discovery your cameras.
  • (New) Able to set Encoder / Resolution / Framerate / Bitrate directly from properties.
  • (New) Hardware Decoding.
  • (New) Wait for Intra Frame (can provide much little latency).
  • (New) Front LED as Tally light...
Thank you for writing this plugin, I'm very happy about this. Sadly it does not work for me (using ZCam E2C with the currently latest firmware 0.96, but this had also been true for 0.95), the camera is found, but as soon as the plugin tries to access the camera stream, OBS crashes completely. I'll keep watching for further releases, keep going!
Best wishes, Bellie
Thanks for the new plugin - it worked great for me. Very minimal latency.
Used it to live stream swimming to youtube in 4K.
Hardware was I5 cpu, RTX2060 gpu, and two Z-Cam E2C cameras (0.96 firmware). Latest OBS on windows. Cpu load was ~20%
Sample: https://youtu.be/8todeikmekg?t=116
Overlay graphics are a product I'm developing.
The new dreaded OBS 27.2.1 Update completely killed and removed this plugin from even appearing in OBS. Is there a way we can get an update for this new version? I use this plugin for my ZCam e2m4 every day and it's been perfect until today.
obs-ssp 0.9.2
This is a bugfix version, mainly fix macOS crash issues.
For windows users, please use obs-studio 26.1.0 or later.
For macOS users, please use the latest obs-studio.
New Feature:
  • "Wait for I-frame" and "Low Latancy" options as default
  • Support Low noise configuration for E2-series camera
Known Bugs:
  • HW Decode H264 crash on windows
  • macOS still may crash on some situation (e.g. change settings when a stream already...
obs-ssp 0.9.3
New Feature:
  • Add support for IPMAN-S, no need to select "Don't check status".
Bug fixes:
  • Change libssp.dll search method on windows, fix not working on obs-studio 27.2.1
  • Fixes H264 Hardware decoding crashes on windows.
Known Bugs:
  • macOS still may crash on some situation (e.g. auto reconnect when a stream disconnected), will fix in next version.
Hoping this Plugin gets updated for the new OBS v28, since it looks like it once again broke a lot of plugins, and I use Z-Cams as my cameras and I need the plugin to work, or else I can't update to the newest OBS.
@xm1994 , is there any news on an update for the SSP for ZCams for OBS? I know ZCam also released their 1.0 firmware update too. Hopefully this gets updated so we can finally update to OBS v28
