VAC won't actually split
furbylovr
I'm using a VAC in OBS to play just specifically spotify out of but no matter what i do its still playing out of the desktop audio? so its playing out of both the VAC and desktop audio.
I have gone into both windows and OBS and switched every default audio i could, i've tried desktop audio 2, i've tried even adding the sound separate as a source and nothing seems to split these two from each other. I currently have the VAC as the default device, i've tried not. I also have spotify's default as the VAC..
as you can see in the screenshot there is double audio. I needed the VAC so i could control that volume separately with a keybind in OBS instead of having to open the application every time i want to pause, mute, etc.
