Tuna
Tuna v1.9.11
Hi, im using tuna with Yt Music app with the correct app like u told me in the tutorial, i have the correct link for the cover (create automaticly btw)
But i cant found the way for the information (title, artist, etc...).
Can u help me, i tried during 2 hours to found a link or an other thing but i cant find anything
thx a lot
thx a lot
The path for the output file is empty.
Dude. Killin' it with this plugin. Thank you!
I'm attempting to pull lyrics from Spotify, is this an option? I've got Spotify set up as my source and have fetch lyrics checked with assigned file name. No gots.
Thanks for any insights!
No, Spotify does not offer API endpoints to get lyrics.
Getting a bunch of these errors in my log, wondering if there's a fix:
[tuna] cURL failed while sending spotify command (HTTP error -1, cURL error 28: 'Timeout was reached')
I am a partnered channel with a music production company, and have to display their info when playing via Spotify. However, every few days TUNA forgets the token and I have to refresh it while broadcasting live. This makes me look unprofessional and I need an idea as to why it keeps doing so. HELP!
Hey all,
I installed tuna today and it was extremely easy to set up and use as someone coming over from snip. However, I also tried to export it to a portable OBS package and everything else was ok but tuna broke a bit. The images still appear but the text does not UNTIL I open regular OBS and it works on both programs. I'm assuming something to do with the text file is look for "OBS x.x.x - profile:" where the portable makes it say "OBS x.x.x - portable mode - profile:"?
Thankfully I'm not going anywhere with the portable package yet and I can make do with the regular version for now but I do potentially want to solely use portable mode.
Thanks.
Hi, Did you ever solve this? I also encountered this issue when I moved to a portable only solution (allowing me to switch between different machines)
hi, I am using tuna for obs to show the file name of current video with vlc player, my issue is if video file has title in its detail file tuna do not show the file name, can anyone help me in this case !
I noticed that there's a visual glitch with the Tuna plugin. For example, in the Basics tab, it doesn't say "Basics", it says "tuna.gui.tab.basics". And pretty much anywhere I go starts with "tuna.gui.tab". Is there a way to fix this?
I'm on version 1.9.9 on Tuna, version 30.2.2 on OBS, on Windows 11.
I didn't have this visual glitch while I was on Windows 10, but ever since I got a new PC that came with Windows 11, I've had this glitch ever since
Hey everyone, just started using tuna recently due to apple phasing out itunes, it seems like no matter what option I use it never shows the artist, the song title and album cover comes over no problem but I've tried {artists} and {first_artist) to no luck. Is there anything I can do to get around that or is it just the windows apple music app being wack? thanks in advance.
You're missing the localization files.
Hello, I was wondering if it was possible to change the font shown ?
Change the font of the text source of edit the HTML if you're using the browser source.
I'm not sure but I assume it's apple music since it works with other players.
Hello! I'm having issues with installing tuna and getting it to show up in the tools tab. I have tried manual and automatic installations and all I can find in my log file is "tuna.dll failed to load". I have tried restarted my pc and obs several times and I just can't quite get it to work. Thank you for any and all help!
