Tuna
Tuna v1.9.11
UPDATE: Ok, I noticed I dont have to go into properties, it starts working when I load the main scene. Its nested in the other where it does not work immediately. As a temp work around, I setup advscnswtr to just imediately goto that scene on startup then back, to get things going.
You are gonna hate me by the time im done. So it was happening way too often so I decided to change the way my scenes were setup, because where the vlc sources were, they were nested in a group to make a script work (if source1 is active, and you activate s2, then s1 goes off, etc), figuring the problem was the group, this time I made a new root scene and put all 3 vlc sources in it and figured id swap'em out with move.
Well I can only get tuna to recognize 1, even though it let me add all 3 in the vlc tab, it will only update the txt file for one of the sources, it ignores the other 2 when they are active. This may have been the issue to begin with? It getting confused by more then 1 source? Even though before they were in there own scenes until nested together in the group.
I was going to make the report on the site, but registrations are closed.
I keep getting the "INVALID_CLIENT: Invalid redirect URI" error message.
Steps:
I open OBS
Open the Tuna Settings, going to the Spotify Page.
I put in the Client ID and Secret then click Open Login Page, instantly getting the error.
I have tried to update the plugin with the latest OBS said there was, making a whole new Spotify Developer App different than the ones that my stream deck uses and it still does not work. I know you said you could not replicate it, but I have been getting this error for a month and a half now, with no luck or any idea how I could fix this. I am aware Spotify did have issues with the API, and around this time was when it went down, and hasn't worked since.
My Spotify developer app works on TouchPortal, and the Streamdeck Plugin. It does not work with Tuna currently.
Yes I do have Spotify Premium
Yes I have had it working before
Ok, I swear this is my last post on the topic, I just wanted to give you a visual as opposed to my long text rant that was likely hard to follow, and was too tired last night. I dont know if this is by design, or a bug. Shows that the titles work fine in a scene with a single source, but include more then one VLC source, even if only 1 is active at a time, tuna only recognizes one of them and ignores the others. Sorry I posted like crazy, Ill try to be more organized next time. ;)
If you added all the sources from the scene to the source list in the tuna dialog, you can switch between the different sources with hotkeys.
I guess picking the first active source should probably be default behavior if there are no mappings.
Edit: You can try this build, which now uses the first active source in a scene:
This change works in a root scene, but if you group the vlc sources or nest the scene it goes back to "breaking", if nested or grouped the hotkey change doesn't fix it either, Ive spent the last 4 hours re arranging my 3 scenes to make it work with move filters and macros and its just not working. Dead in the water. Funny thing is, if you have 3 individual root sources with 1 vlc src in each, once they get grouped or nested, even though everythings in its own world at the top level, it goes back to only one working, mapped or unmapped, the hotkey wont make it work either, only if mapped and all 3 in the same top scene. Got work tomorrow so I gotta take my ass to bed.
Wish I had backed up were I was before attempting this last 4 hours... So much to revert...
hmmm, I looked, nobody else supports the vlc source that I can find... how much would I have to scrounge up to "motivate" you ;)
It's most likely just a small change so anything is fine, but keep in mind that I don't have patreon or paypal, there are only some wallets linked in my signature.
Thanks for reaching out! I was using 1.9.5 already. The build just uploaded makes things fail entirely. No track cover can be displayed at all, which is funny...
I replaced placeholder.png with a rounded rectangle, so well.
The cover, attached to the audio f ile and recognized properly by vlc.
Tuna isn't fetching from vlc's directory (which seems to be already problematic). Instead it goes search on itunes, and gracefully returned a parse failure. Then it falls back to placeholder.png and keeps pumping out errors saying 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist, though it has this runtime cover file created for like 5 times, as I observed in file explorer.
22:09:32.868: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:36.620: [tuna] Couldn't parse json from url https://itunes.apple.com/search?ter... -SEPARATED EDITION-&media=music&entity=album: illegal value
22:09:36.620: [tuna] curl_easy_init() failed when receiving json from https://itunes.apple.com/search?ter... -SEPARATED EDITION-&media=music&entity=album
22:09:36.670: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:38.819: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:39.823: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:43.331: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:43.940: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:44.473: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:45.011: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:45.528: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:49.997: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:53.469: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:09:54.982: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:10:16.334: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:10:16.336: [tuna] Couldn't fetch json from https://itunes.apple.com/search?term=Eurobeat Union EURO BAKAICHIDAI VOL.18&media=music&entity=album curl error: Couldn't resolve host name (6)
22:10:16.336: [tuna] curl_easy_init() failed when receiving json from https://itunes.apple.com/search?term=Eurobeat Union EURO BAKAICHIDAI VOL.18&media=music&entity=album
22:10:16.834: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:10:16.835: [tuna] Couldn't fetch json from https://itunes.apple.com/search?term=Eurobeat Union EURO BAKAICHIDAI VOL.18&media=music&entity=album curl error: Couldn't resolve host name (6)
22:10:16.835: [tuna] curl_easy_init() failed when receiving json from https://itunes.apple.com/search?term=Eurobeat Union EURO BAKAICHIDAI VOL.18&media=music&entity=album
22:10:17.332: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:10:18.456: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:10:19.304: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:10:20.170: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:10:23.522: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:10:26.888: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
22:10:28.552: [tuna] Cover file 'D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg' does not exist
Past attempts include:
- making sure "fetch cover" was checked and vlc as song source was chosen
- accessing D:\Personalis\Virtual_Profiles\Streamer\Runtime\Tuna Now Playing Cover.jpg successfully in web browser
- restarting tuna
- restarting pc
- playing multiple tracks (~20)
- chown the entire runtime directory to everyone full control
- falling back to release v1.9.5, which still partially works as stated before
Hi, super new here! I'm trying to stream a few videos on OBS 29.0.2 with VLC Source (VLC player 3.0.18) and overlay the file titles on top. However, Tuna settings (Version 1.9.5-HEAD) doesn't show the option to add any "Song info outputs." Any help would be really appreciated.
resize the window
LOL~ feeling real dumb. THANK YOU!
While I'm at it, I have another dumb question...
Under "Song info outputs," I tried to "Add new" with Song info path as an empty txt file "tuna.txt" and song format as "file_name" but nothing happens and it doesn't even get added.
What am I doing wrong? I even created a text source "Text (FreeType 2)" but nothing has worked.
I've also explored adding the same txt file "tuna.txt" as the text file inside text source and didn't help. It's odd that song info outputs won't add anything whenever I have something in "Song info path."
I can only create song info outputs without a song info path. When I try to edit it with "tuna.txt," it automatically deletes it from the outputs.
I don't know, try manually creating the file with the path "/Users/home/Downloads/tuna.txt" and then try readding the output with that path. Tuna checks if it can write to the path and should create the file itself, but who knows what macos is doing.
when I originally posted that the plugin wasnt working I was trying to use { filename } as well, I dont think VLC supports the filename tag.
try { artist } - { title } just to see if it works and go from there.
Where are the Flatpak manual file install locations for Tuna? I have the .so in ~/.var/app/com.obsproject.Studio/config/obs-studio/plugins/tuna/bin/64bit/ and that lets me pull up the Tuna GUI, but all text is replaced with the placeholder tuna.gui.tab.basics.song.cover stuff. Where does the locale folder go?
As a hint, the outputs.json file got sent to ~/.var/app/com.obsproject.Studio/config/obs-studio/plugin_config/tuna/outputs.json Maybe somewhere around there?
It seems to be working otherwise.
