Tally Light Software
Free Tally Light Software version 1.3
josephdadams
josephdadams submitted a new resource:
Tally Light Software - display tally lights for active sources or scenes in OBS
I have created a free tally light solution that is compatible with OBS (and other sources). It is designed to let you configure multiple incoming tally sources like OBS or a video switcher (ATEM, Carbonite, etc.), and aggregate them together. You can view tally output on a browser, phone, or tablet, and you can use blink(1) USB lights on a Pi Zero for tally over Wifi. It also supports GPO output, contact closure relays, etc. In order to work with OBS, it requires the websocket plugin.
Hey Joseph, very cool project! I love how cross-platform you have made it. I think it is awesome that you have open-sourced your project. Have you seen a lot of interest and use for your software so far?
I designed and built something similar for my own purposes using a closed-loop wired serial interface. I am considering open-sourcing my project as well. Here's a link to a demo of my tally light project in action.
I designed mine to be wired because I had conerns of Wi-Fi interference and latency. Have you seen good reliability over Wi-Fi?
Let me know if I can contribute in any way to your project, or if we can collaborate somehow.
Last week I was asked if there is a possibility for the speaker to check which camera is active... We use 2 PTZOptics Cameras (30x, NDI, latest model), controlled via obs. I found out that there is a possibility via VISCA Commands to use the LEDs from the camery as tally.
Tally OFF: 81 0A 02 02 03 FF
Tally BLINK: 81 0A 02 02 01 FF
Tally ON: 81 0A 02 02 02 FF
Can you add this output possibilty to your tally-plugin? That would be great :-) [I read the little description and could not find anything using VISCA/PTZCameras as output]
Thanks in advance,
Christian
Hi Joseph,
Thank you for your great project!
We are a cultural association and since Corona we have been doing many cultural events as live streams.
We use three cameras and OBS Studio. Now we are planning to buy a Datavideo ITC-100 which has two tally inputs (https://www.datavideo.com/us/product/ITC-100). The belt packs each have a two-colour tally light.
Do you have any experience in setting this up?
Thank you!
Cheers,
Carsten
Hi Matt!
Unfortunately your link says: " The requested file is no longer available!" :-(
Hi Carsten,
Please see my GitHub, I have a basic demo video there, plus all the source code and 3D files: https://github.com/mattv8/obs-wired-tally.
Here's my OBS forum project post: https://obsproject.com/forum/resour...-for-obs-arduino-rgb-leds-obs-websocket.1079/
Here's a video I quickly made illustrating how my tally lamps work by source rather than by scene in OBS: https://photos.app.goo.gl/kqT6DxCsHpvZyUQ76
Right now my project only supports OBS but I'm working on bringing in functionality with JosephAdam's TallyArbiter so it will work with a number of different sources. Stay tuned on that by keeping an eye on my GitHub or OBS forum post.
-Matt
josephdadams updated Tally Light Software with a new update entry:
Version 1.5 is now available
Many updates have been done since I last posted here about Version 1.3. You can find all the details at the Github link or at www.tallyarbiter.com
Some of the highlights of 1.4 and 1.5:
  • New interface built with Bootstrap
  • Improved support for Blackmagic ATEM
  • The GUI has been revamped with all internal socket.io calls. The REST API still exists, but this will be more streamlined.
  • A Generic TCP Device Action has been added: Now you...
Hi Joseph,
Thank you!
Cheers,
Carsten
CarstenFabian, Sorry for just now replying to this. I somehow got behind on these messages, and I apologize. I do recall seeing where someone integrated Tally Arbiter with their DataVideo ITC-100. https://www.facebook.com/groups/1572662719665042/permalink/2726468657617770
Hope this helps!
just installed and running perfectly as a node on OSX 10.15.7 but can't get it to install as a service. Followed the directions in the readme but it keeps coming back "permission denied" what am I missing? (sorry I'm horrible at this whole coding thing)
Re: Tally Arbiter v2.0
Is there any way to disable the Preview / Program swap in OBS when using studio mode? Or perhaps light the Program only?
Thanks in advance!
josephdadams a soumis une nouvelle ressource :
Logiciel Tally Light - Afficher les voyants de comptage pour les sources ou scènes actives dans OBS
En savoir plus sur cette ressource...
Bonjour,
Je me présente, je m'appelle Sylvain.
Nous avons un plateau TV avec 5 caméras tourelles datavidéo PTC-140 équipées de TALLY.
nous utilisons le logiciel OBS comme switcher vidéo, et je possède un boîtier,
Blackmagic GPI et Tally interface
Puis-je le connecter à votre logiciel Tally Arbiter, pour faire la liaison entre OBS et les Tally Datavidéo ?
la liaison entre GPI vers dataviodéo fonctionne, la liaison entre OBS vers tally abriter fonnctionne aussi
Mais je n'arrive pas à faire la liaison entre Tally abriter et le GPI
Voici le lien de notre chaîne youtube
https://www.youtube.com/@lecuberec
Merci d'avance pour votre réponse.‍
Je vous souhaite une agréable journée
Cordialement
Sylvain
Hello Joseph; Everyone: I have 2 X Datavideo PTC-140NDI cameras installed as part of a church live stream operation, and I would like to make use of the camera's built-in Tally Lights, using Tally Arbiter. In the camera Settings, I do not see a Tally Light reference (Enable). Has anyone had experience with these cameras in a Tally Arbiter/NDI situation?
Cheers. . .
Tony N.
