Source Clone
Source Clone 0.2.3
"A" is a Source
"B" is a Source Clone of "A"
"C"
is a Source Clone of "B"
Does "C" actually clone "B" or does it go straight to the source which is "A"? Does it affect CPU Usage either way?
@TMBGeeks in that case C will clone B, so all filters on B will be visible on C. The CPU and GPU usage depends on lots of things, what are you trying to achieve with the source clones?
Just trying to future-proof my layouts. Sometimes, due to lots of scene nesting, I lazily clone B when I should technically be cloning A, a habit I just need to break.
Hi Exeldro!
I get the Create/Select Source window, but when I choose Create new, and type an existing Source, I get an error that the name is taken. The Add Existing Window is blank and I am unable to type anything in there. Here is a screenshot of what I get.
Ok. I have tried removing and replacing this as well as a bunch of other plugins...spent a couple of nights doing this, but still the same thing.
Just wondering if anyone has gotten this to work in OpenSUSE TW. I'm using the flatpak version and it wont load no matter where I put the source-clone folder. Normally I would just add a plugin to the plugins folder, but that isn't bringing it up.
Hey Exeldro! thanks for all the plugins, I've got a question, dunno if it's a bug. I cannot clone a display capture, maybe that's not possible?
@Ferpipe and @Cassian67Volt cloning a display capture works fine for me:
What part is not working for you?
Is there anyway to have it cache the previous scene until the current transition finishes?
Current have issues where when using a source clone set as previous scene, that source changes during transition to the next scene (or for me, back to the original scene).
Even if it were just an option to input a certain amount of milliseconds after scene change before the source clone updates what the previous scene was so that it doesn't change during transition.
Loving this and many of your other plugins you've created!
Hey! Im looking for help, suddenly some of my cloned sources stop worked, specificlly the one with filters on them. I tried to reinstall obs, downgrade the obs version and, ofc, reinstalled the plugin but nothing works. If i add another clone source it works, but if I want to add a filter it stop showinn image. Can anybody help me please?
Could someone explain me what "Active Clone" means for this plugin?
Does it mean it stays active even if i switch to another scene or does this mean from all the clones out there this ones active and possible skynet is going to happen. Jokes aside. Or does this mean this active clone can now also be cloned? Or is primary clone?
I have been using this plugin to clone my webcam and my media source for a while. But after the recent OBS update, the plugin causes my preview to stay blackscreen when I am at the scene with that webcam clone source. I have removed and added back the webcam as video capture, and now the plugin won't work video capture sources
Since the latest OBS update, if i use nested Scenes I had a problem with media playback. They are only triggered once, and nothing happens the second time.
I'm having a weird issue where when I create a source clone it doesn't include the "no filters" option. I did try uninstalling and doing a fresh install, and I checked to make sure the DLL was removed, but alas. Did I miss something?
