Question / Help Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found
the_algar
Hello from Paris France
Here is the latest log from OBS studio - Seems to have a routing issue has the "missing" files are present indeed in the folder
Can you help ?
log file is here: https://hastebin.com/awuwejefaj
extract
16:01:44.879: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
16:01:44.907: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
16:01:45.119: [AMF] AMF Test failed due to one or more errors.
16:01:45.119: Failed to initialize module 'enc-amf.dll'
16:01:53.362: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
16:01:53.389: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': (null) (127)
16:01:53.389: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
16:01:53.754: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
16:01:53.975: [browser_source: 'Version: 1.31.0']
16:01:54.264: NVENC supported
16:01:54.625: Couldn't find VLC installation, VLC video source disabled
16:01:54.693: No blackmagic support
This message is normal and nothing to worry about, it's a component of the Browser Source, and not an actual plugin which is why it fails to load. There is nothing wrong.
Are you trying to solve an actual issue? If so, please provide the details to the issue itself so we can help.
well the issue is the recording doesn't work at all and the message I got is:
in french - le démarrage de la sortir a échoué. Veuillez consulter les journal pou plus de détail - meaning "starting the output has failed. Please consult the journal/log for more details
Hello - did this - it now record a black screen when I try to record in screen capture.
So it's an improvement but far from the desired results ,-)
