Recording VHS tape
classystyle990
I am recording a VHS tape, and my setting in OBS for resolution is 1920x1080. It seems the video is getting cropped/I'm only seeing the upper left quadrant of the film. Is there some other setting I need to adjust to be able to record the full screen?
Make sure that you set right resolution in the "Video Capture Device" properties (accessible via the right-click menu over the source in OBS).
Also, there is no much sense to record VHS in FullHD. The only reason I see is when your capture card scales the feed up to 1920x1080 and no other options exist. Common resolutions are: 640x480, 768x576, square pixels, de-interlaced, aspect ratio 4:3. May look blurred in comparison to modern videos, but this is by design.
