Bug Report Problems with Window Capture
narwhalcat
So I have been using obs classic for about a day now, and up until now i have been having no problems. I wanted to take a break from my stream so i stopped the stream and then closed it. When I opened it back up it seemed normal but when i launched the league client (Left monitor) it was very zoomed in as seen on the obs client (right monitor) i tried switching to game capture for the client but that only caused it to be a black screen. I have looked this up and they said to check the resolution, i played around with the resolution, setting it to different values including my regular values but none of them worked. Any help? any more information I need to provide, I will do my best to provide. ( there should be a file attached, not sure if it attached. it looks like it wanted to, and it isn't showing the attaching/loading sign anymore so im hoping it attached)
Note: When I use the older League client it works just fine.
Ohhh I've had that happen. That is super annoying! I don't know how to fix it. Outside of changing the resolution of your monitor (not the game) to match that of the game instead, you can edit the scene and drag it to fill up the screen.
