animalshadow
animalshadow submitted a new resource:
Pomodoro Pro Timer for OBS - The Customizable Pomodoro Timer for OBS
Elevate your streaming and productivity sessions with our Customizable Pomodoro Timer, exclusively designed for OBS. This intuitive and adaptable script helps you implement the renowned Pomodoro Technique directly into your live streams or recordings. Break down your work into focused intervals (traditionally 25 minutes), followed by short breaks, to maintain concentration and creativity.
Features:
  • Customizable Durations: Tailor your focus, short break, and long...
heyy i just tried your script and i really love it. is there any chance that it could include like a session text as well per rounds of pomodoro like this?
Could you please tell me how to get it into a scene as a source?
download the lua file on his acc. it'll say pomodoro.lua > open obs > click tools along the upper left half > Click scripts> click add or + button > choose the file pomodoro.lua make sure that the title of your source is the same as the name of your pomodoro, so change the name of your text source as "timer" to match your pomodoro. then you can adjust accordingly
Hey everyone,
I just made my own version of a Pomodoro Timer for OBS. This version is based upon this script here.
Here’s what’s new in my version:
Reordered Controls: The Start and Stop buttons are now at the top of the settings panel, making them super accessible during live sessions.
Auto-Stop on Max Sessions: The timer will automatically stop once you hit your preset number of focus sessions.
Fast Mode for Testing: For those times when you don’t want to wait forever, Fast Mode lets you run the timer at an accelerated pace (1 real second equals 1 minute).
Customizable Durations & Messages: Adjust the focus, short break, and long break durations, along with personalized messages.
Sound Alerts: Get notified with a sound alert during transitions—just set up your media source, and you’re all set.
Check it out: https://obsproject.com/forum/resources/pomodorotimer.2094/
Cheers,
Paul
hi, how to view this script on the scene? I don't see it :(
first, add a source and then title it with something like "Timer" or "pomodoro". go to the "tools" att the upper left menu and click scripts. there you can see the + button and click and add your pomodoro.lua, entitle your source the same as the one you added earlier. it must be the same or else it will nott show up
animalshadow updated Pomodoro Pro Timer for OBS with a new update entry:
Pomodoro Pro Timer – New, More Reliable and Feature-Rich Version
This new release brings major improvements in reliability, control, and user comfort:
Improved Reliability
  • Verifies audio files exist before attempting to play them.
  • Non-blocking audio handling to prevent freezes.
  • Protection against invalid or illogical settings (sessions, minutes, etc.).
New Features
  • ON/OFF toggle to enable or disable sounds.
  • Mappable hotkeys in OBS: Start, Pause, Resume, Reset, Skip.
  • Auto-Start per Scene mode...
New Features
can you help me with a problem?
i downloaded, and followed the steps in readme.txt, it works except the timer is going wayyy too fast. 4x faster than real time. so 1 minute is finished in 15 seconds.
do you know what might be the problem and how i can fix it?
thank you so much =D great program otherwise
I'm having the same issue. Not sure how to solve it, but hoping a suggestion will come up.
v3.3.0 - Speed bug fixed, wall-clock accuracy, and many new features
This is a big reliability and feature update.
Fixed
- The timer running too fast (2x, 3x, 4x, "one minute in fifteen seconds"). It was caused by pressing Start more than once, which stacked hidden timers on top of each other. Start now guarantees a single timer, so it always ticks once per second. This resolves the reports from octavebits, Nyx Goldstone and others.
- The countdown is now wall-clock accurate: it is anchored to an absolute end time, so it stays correct even if OBS lags or...
@octavebits @Nyx Goldstone Thanks for the reports, and sorry for the trouble. I found it: pressing Start more than once stacked hidden 1 second timers, so the clock counted several seconds per second (three presses = 3x, four presses = 4x). The fixed version (3.3.0) makes Start always use a single timer, so it ticks once per second no matter how many times you press it. It is going through the forum review right now and will show up as the current version shortly. Once it is live, just download it again and reload the script in Tools > Scripts. Thanks for your patience.
@jowanne good news: the per-round session text you asked for is built in now. Turn on "Show session counter" in the script properties and the timer shows the current round, like "Session 2 of 4". You can also rename the "Session" label. Thanks for the suggestion!
Thanks @jowanne for helping out. To make the "I don't see it" case foolproof: the script only writes into a Text source whose name matches the name in the script's source field. So create a Text (GDI+ / FreeType) source, then either name it exactly like that field or paste your source's name into the field. They have to match character for character, that mismatch is the usual reason nothing appears. The new version (3.3.0) makes this obvious: it shows a setup hint at the top of the script properties, and if the name does not match it writes a warning in the Scripts log. @GalloGlass @mest this should sort it for you.
