OBS no longer starting on macOS
mjbright
I've been struggling off and on for a month or two with OBS which simply won't start on my Mac.
Environment
I'm currently running OBS obs-studio-29.1.3-macos-arm64, but the problem occurred with several other v28 and v29 releases.
I'm currently running macOS Ventura 13.4.1 on a 2021 MacBookPro M1.
I've reinstalled OBS many times trying to fix/understand the problem.
Symptom - launching from the LaunchPad
The symptom has been that when starting OBS from the LaunchPad, no window opens.
I see the OBS icon in the dock, bobbing up and down.
After several seconds I see "OBS Studio (Not Responding)" in the macOS "Activity Monitor".
NOTE: OBS has both screen recording and accessibility permissions
Launching OBS from command-line (iTerm2)
As no Window is opened I don't know how to send the log file ... BUT I've been experimenting with starting from the command-line (iTerm2).
I'm essentially launching OBS using the command
/Applications/OBS.app/Contents/MacOS/OBS > obs.log 2>&1 &
iTerm2 (w/o screen recording permissions) + launching OBS => Window opens (but no screen record permissions)
Amusingly, I did manage to get the OBS window to open whilst iTerm2 didn't have "Screen Recording" permissions !
I've attached log obs.iTerm2.screenrecord.WithoutPerms.log
iTerm2 (with screen recording permissions) + launching OBS => Window doesn't open
Giving "Screen Recording" permissions to iTerm2 I get the same OBS icon bobbing up and down in the Dock.
I've attached log obs.iTerm2.screenrecord.perms.log
No reply - no problem, I was about to open an issue on github but discovered that the problem has sorted itself out somehow :)
I am having this same issue and it has not resolved. I run OBS 29.1.3 (64 bit) on a 2023 Mac Studio running MacOS Ventura 13.5. Mac Studio has M2 Ultra, 64 GB unified memory and 2TB SSD. I am wondering if the Uniifed storage is causing problems because I have the same setup on a 2020 MBP 14" running the M1 Max chip with 32 GB of memory.
On the Mac Studio when I open OBS it will say not responding in the Force Quit screen.
Any help would be much appreciated. Thanks.
I've been having Mac OS issues too with my obs. Do any of you guys use cameras that are the exact same USB name: multiple copies of the same one? I just want to see if your issues are related to my issues. My issue is that when I try to call a camera, OBS just crashes. An OS 13.5.1 it was kind of usable annoying in 13.5.2 it became unworkable. I discussed my situation on a different entry in the OBS project forum. Last time the OBS people told me that there's nothing they could do until Apple has a way to differentiate two different cameras of the same name without relying on the manufacturer to have a way to do it.
@tripletopper: Yes! I also have two of the same cameras. OBS has become unusable. I just unplugged one of my cameras and all of the sudden I can start OBS again!
Strangely, after OBS is open and running, when I plug my second camera back in, it seems to work. I only just did this minutes ago. I suspect it will stop working in a bit. But this has gotten me unstuck. Thanks!
Im having the same issue, can't launch OBS (sometimes I can, when deleting and re installing, but then a few moments later can't open it again). I hadn't this issue before, I notice it started (literally) the moment I make an ssd backup of an old MacBook (2011) using my now main MacBook (backup to another drive, through this Mac). I mess around with some "permissions" of folders of that old ssd, and I just copied everything (including apps - I realized there was an old OBS app). I was running OBS (while doing the transfer, because I was testing some ideas), and when I unplugged the drive where was receiving the backup, I couldn't launch OBS again. And I don't know, I deleted some of those files in the backup and deleted OBS and installed it again, and kinda work, but Im just having the same issues again and again.
*Temporary Fix* ... I'm having the same issue. My workaround is to install OBS-Studio-30.0.2-macOS-Apple.dmg and reboot so the virtual camera works.
I've found that any release after 30.0.2 doesn't work for me on my setup:
  • Mac Mini, Apple M2 Pro, 32Gb
  • Sequoia 15.0 (although the above was true for OX 14x too)
I keep a copy of the above installer file safe if I succumb to temptation and accidentally instal the latest version of OBS.
I hope this helps someone else.
I found the caused and solution. In macOS Sequoia, the Camera Extensions permissions are no longer under "System Settings > Privacy & Security" (this is where the installer was trying to point you to). The new place to approve it is under "System Settings > General > Login Items & Extensions" scroll down to "Extensions" section and click on "Camera Extensions". This is the Way :-)
I am having this same issue but your solution is not working for me. My camera extensions was already on with OBS. Not sure what to do now.
I am running the iMac OS Sequoia 15.3.2. I have tried every way to install it. I was able to use the torrent, however it get this symbol over the app. I also followed the above instructions regarding the Login Items & Extensions and still cannot get any success. Maybe someone has some info on this issue?
Same issue - MB Air M3 Silicon - Sequoia 15.3.2. Mac is not recognizing the card I get the same image. Repeated all instructions and restarted with no love.
This is what Apple messaged me this morning. I attempted download from OBS website (DMG) I use Intel version. Followed these instructions, and boom.. it worked. I hope this helps you.. I fought with all this for days... now I begin the learning curve.. lol. Let me know if the instructions worked for you.
1 Open System Settings.
2 Click Privacy & Security, scroll down and click the Open Anyway button to confirm your intent to open or install the app.
3 The warning prompt reappears and, if you’re absolutely sure you want to open the app anyway, you can click Open.
I am able to install the app = the app cannot find the source. :(
I had the same issue. I downloaded Appzapper. Then opened it and dragged my already installed obs into it, so as it would delete all OBS installation files, folders, caches etc.
Then I re-installed OBS again, it worked and appeared well.
