Bug Report OBS crashed !!?
nhrrrr
hi
last night i change video stream resolution as normal then AMMMM. (you know)
i try to reinstall and same thing
i hop there is no security issue effected my computer with log file ( attachment )
i will try to uninstall and install again
after uninstall and clear all files i install OBS from Zero
Actually the program still crashed
**when i try to maximize program to full screen
** also when trying to move the program from main screen to 2nd or 3rd screens
both log file in attachment
GL
  • OBS crashed.txt
    OBS crashed.txt
  • OBS crashed02.txt
    OBS crashed02.txt
hi again,,
after troubleshooting, i find there is some error between main display and OBS. when i change the main display the program work without crashed....
i dont know is it form OBS or windows !??
that's it ?!!
