OBS Black Screen when recording??
elixr
Hello! I am new to using OBS and I looked up some tutorials on how to use obs. I pretty much used them to only change my bit rate so I have less lag and more fps. For some reason no matter what encoder I use, I get a black screen when recording. Everything runs the same except the black screen. Can someone PLEASE help me?
My system specs:
Intel i5-10300h
16gb DDR4
Intel UHD Graphics
NVIDIA GeForce GTX 1650 TI
Log File: https://obsproject.com/logs/gtMKmiVksRWj0ohM
A picture on what it shows:
Once again, I will really appreciate the help. Thank you in advance!
same issue here, are you on Windows 10 version 2004 by chance? and does capture window work properly?
Yes, I am on Windows 10 version 2004. Capture window works properly. I can't do display capture which is what I need. I also used the auto config wizard for OBS and that didn't fix my problem.
