Status
Not open for further replies.
I too am having issues when connecting to OBS Websocket Plugin on 127.0.0.1:4444. Have restarted OBS and Lioran Board Receiver multiple times. I was only able to connect to OBS Studio 1 time during the initial setup and nothing after that.
I just started trying to use it today.
Just to add some additional info. I confirmed the Default port of 4444 is open and accepting connections, so it has to be something in the way lioranboard is connecting.
I am having an issue that I don't understand. I have an action that has the variable of switching to the previous scene, but in the command section, I told Lioran board to go to my 1x Zoom Scene, but it's not going back to the previous scene even though /$previous_Scene$/ is in the list of parameters. Did I do something wrong? Am I miss using the command or misunderstanding the use case for this? I need help and would appreciate an explaination.
This tool looks amazing but unfortunately I can't link my twitch account. It timed out or something after I submitted the authentication and now I'm stuck with this:
Any help would be greatly appreciated as I think this can really add value to my stream. Thanks :)
Why is does the receiver only connect to localhost 127.0.0.1? If the user could simply set the IP couldn't a PC running both the transmitter and receiver control a Mac? I tried changing the local address in the code using a hex editor, but then I got a checksum error. I thought it was worth a shot.
Beim Neustart des Recievers übersteuern meine ogg. Soundfiles die ich bei Sound Effects eingefügt habe habe. Ich muss vor jedem Stream den Reciever starten die "Curb Your Enthusiasm Theme" einfügen abspielen und danach durch mein Sound.ogg ersetzen damit es nicht mehr übersteuert. Kennt jemand dieses Problem?
Grüße Zinki
Hello! I just tried to open the receiver but I was given the following code error.
___________________________________________
FATAL ERROR in
action number 1
of Async Event: Networking
for object obj_host:
ds_list_size argument 1 incorrect type (undefined) expecting a Number (YYGI32)
at gml_Script_scr_websocket_inspect
stack frame is
gml_Script_scr_websocket_inspect (line -1)
gml_Script_scr_receive_websocket
gml_Object_obj_host_Other_68
Has anyone seen this?
FATAL ERROR in
action number 1
stack frame is
Out dated or inproperly installed OBSwebsocket has always be the reason for that error
Thanks Lioran so much for your quick reply! However, the OBSwebsocket works fine with Touch Portal. Should I just try to reinstall it anyways?
as far as i can tell, touch portal is compatible with old version of OBSwebsocket... Lioranboard is relatively new and so is not compatible with older versions. If you're not on 4.8.0 it might not work properly or at all.
I had people tell me they were on 4.8.0 many times and saying they sitll get the error but problem was fixed once they reinstalled OBSwebsocket properly. I can't tell you what they're doing wrong, but that error can only happen when obswebsocket sends something that is unexpected, which shouldn't happen unless old or mis-installed
Okidoki Lioran! Thank you so much!
Got a quick question here:
I created a command that makes a scene become active whenever a chat message appears. It is a smartphone with the messages on screen to display my chat on screen. I have it set to stay active for around 15 seconds and then disappear. Works great.
However, is there a way to just keep this scene active until there is no activity in chat for a period of time? To prevent the scene from switching when it is not needed. Also, can you create a filter to ignore Bots or commands?
Thanks!
Hey there!
Having a crazy issue. No anti virus, no voice meeter.
If I click away from the program is closes completely. No matter what I do, I can't get it to stay open after leaving focus from the window.
Suggestions? I've Tried 3 versions.
Faulting application name: LioranBoard Receiver.exe, version: 1.3.9.0, time stamp: 0x5aa7bf57
Faulting module name: LioranBoard Receiver.exe, version: 1.3.9.0, time stamp: 0x5aa7bf57
Exception code: 0xc0000005
Fault offset: 0x00046fa8
Faulting process id: 0x3f44
Faulting application start time: 0x01d6f60dda23e096
Faulting application path: C:\Users\flame\Desktop\Spliffrite\LioranBoard\LioranBoard Receiver(PC)\LioranBoard Receiver.exe
Faulting module path: C:\Users\flame\Desktop\Spliffrite\LioranBoard\LioranBoard Receiver(PC)\LioranBoard Receiver.exe
Report Id: 941ce902-51b7-4d5b-8153-529824d6ac64
Faulting package full name:
Faulting package-relative application ID:
When I try to connect to twitch in the lioranboard receiver I get sent to an error website page. Does anyone else know how to get around this? I used to be able to do this no problem, but now I can't connect to twitch
Hey Guys,
Im having an issue with trying to get Lioranboard to recognise the filters I've applied. It simply shows "no filter for this source" even tho i have applied them to the source within OBS.
I've updated to latest version of both lioranboard & OBS. Any ideas?
Status
