Status
Not open for further replies.
Hey @lioran,
last week or so I haven't been able to get the chat commands to work, on my account or any of my mod accounts. Any ideas? I currently have to use channel points which is cumbersome. Thanks :)
your token might be outdated, try to get a new one, delete connect.ini and try again
Hey Lioran thanks for getting back to me. Now the TSL isn't working. I am applying it the same way it was but now it wont connect to twitch and the button is greyed out.
Ill attach screen shots to make sense of what i'm saying.
Thanks man.
Thanks man.
you didnt change the listen port from the default 9423 did you?
Now that ive thought about it, this issue came about after I changed my twitch username, could you think thats the problem?
its really hard to help with this kind of stuff over the forum, should hop on the discord instead.
but yes changing user name will prevent lioranboard from connecting since its trying to connect on an account that no longer exist.
as i mention before, delete connect.ini
hey!
i constantly have issues connecting to the obs websocket plugin, + i cannot for the life of me figure out why. everything has been set as an exception by my firewalls, everything's running as admin, everything's using the latest version available, and the port number has never changed from 4444. the only way to finally get it to work is to close + reopen everything multiple times until it finally works. last time, i opened the stream deck, + that somehow made it connect. tried that again the next time it wouldn't connect, + nothing.
it's a hassle to go through every time i go to stream. if anyone has any ideas, i'm open to them.
So, as the guy above said, websocket is not helping, a few weeks back i made lioranboard work, but now, im trying to connect again and im connected to twitch, but cannot connect to OBS, tried executing normal and administrator mode and nothing, closed and opened multiple times both programs, it keeps saying cannot connect to websocket. No configs were changed and i deleted connect.ini as on other posts.
If the IP at the bottom, when it fails to connect doesn't say 127.0.0.1:4444
Go in in the lioranboard Receiver folder and appdata/local/lioranboard and delete both connect.ini files in there
As you can see the IP is correct, the folder you mentioned (appdata/local/lioranboard) does not exist, searched all appdata, and as mentioned before, i deleted connect.ini from receiver folder already and did not work.
I'm having an odd problem: I'm trying to start OBS from LioranBoard. I've copied the File Path from a shortcut that works already (C:\Program Files\obs-studio\bin\64bit\obs64.exe). When I tap the button on the LioranBoard Stream Deck, I get an error message that OBS "Failed to find locale/en-US.ini" which is right where it should be in the data folder.
Suggestions. (All of my other Execute Program buttons seem to be working.)
The following command actually works in the command line:
start "it's obs" /d "C:\Program Files\obs-studio\bin\64bit" obs64.exe
but when I insert it into a Command Line command in LioranBoard, it does nothing. (There's no error message, but no program run either.)
So the "solution" is to put the command above into a .BAT file and call the file in an Execute Program command from LioranBoard. That actually works. Also, you don't need the "it's OBS" in the line. That's just a title for the console window.
Been having issues with the " Follower Alert " extension. Pressing the "Test Follower Trigger" button will activate a scene change in OBS perfectly, however whenever I receive a new follower on Twitch the event doesn't trigger. Any thoughts as to why that might be?
you need to activate it first, just need to do the command "Send to Extension" and set it to follower alert , leave the channel_id box as it is. and you need to do that command once after the transmitter connected. And that's it.
Do I add this to the button/trigger I want connected to lioranboard, or as a separate command? For now I've added it to the button/trigger I want connected to the Follow event--will have to wait until Wednesday to test
Hi I am having issues with the Android app. It connects to the receiver, but then disconnects, and keeps repeating. My board never fully loads, instead it gets stuck on the green background of the app. I have to force close the app.
green screen = its not connecting
check the ip make sure its the right one, if you left it to default, yeah, its not gonna work
The follow event still doesn't seem to react to Twitch Follower notifications. Under Edit Commands for the deck button I added Send To Extension > Follower Alert with the channel_id set to /$channel_id$/. The button works when I press the test button in OBS, but not when I am live.
In lioranboard 1.39 there is a button you can create that's called "latest follower button". its recommended to use that, just create that button and add whatever commands you want to it. just don't modify the existing commands that are in there and leave them at the top. It's meant to work as a 1 button follower alert. instead of having 2 seperate buttons.
Now if you say its still the same, works when you click the test button but doesnt when you're getting followers. you have to keep in mind lioranboard follower alert uses polling from twitch and relly on twitch's caching to be updated. which happens roughly every minute, so wait a minute or so to see if it happens. That delay is unavoidable without a server for the webhook which lioranboard doesnt offer
Status
