Duplicated mouse bug in screen recordings (ZoomIt + OBS)
290459358939
A second "ghost" mouse appears inside the recording when using OBS for a display capture/screen recording and zooming in with a tool like ZoomIt.
OBS emulates mouse pointer. Internally, OBS grabs only position of the pointer and draws picture of the mouse pointer at this position over the desktop picture. This is because of how cursors are rendered in the OS itself (accelerated by GPU). So, there is special setting in "Display Capture" source of OBS to not capture the cursor - this should help with "normal" not zoomed pointer.
There is script that may help to enlarge only OBS source (Transform it) with hotkeys. It was mentioned in:
Thank you Suslik V,
I've just fixed it now by opening and closing the Studio Mode. Somehow, this gets rid of the duplicated mouse.
