Draw
Draw 0.3.1
  • 2025-02-25 12-10-38.txt
Running Mac OS 15.3.1 I downloaded and installed, but it is not showing up in my docks. Could you help with a resolution?
Their are three installers for Mac. I typically use the universal installer, but it didn't work, so I tried one of the other ones for intel Mac. It works great! You might need to use the one specific to your Mac OS and OBS version? I hope this helps.
@Excelrdo This option is really great! I suggested this a while back and so glad to see it come to life! Thank you! I'll be playing with it for my weather updates! When you look at this plug-in next, could you enable the placement of Text? This would help me interactively label things like storms, hurricanes, etc. Just one click then the text (looking like a pen or whatever font is chosen) gets applied on the draw overlay. Thanks! I used to work on weather graphics systems as a user interface applications engineer...but I'm not a programmer. Perfect timing for hurricane season!
Tried the more specific installer, I still get the blue overlay and crash as described above. @Exeldro , was there anything that explained the problem I'm having in the log file I uploaded?
I'm not a programmer, so I don't know how to read log files, but want to help. I seem to have peculiar things happen and have been happening since the beginning of time. I would first try safe mode. It disables alot of stuff, so this will tell you it's not OBS or your Mac. It's 3rd party plugins that don't work nicely together. You could also start a brand new scene, which I think doesn't bring along lua scripts. If it works you need to reinstall the .lua scripts one by one. The other thing would be to make a back up of everything then delete it to start new. i would fully make sure you know how to do it first, so you don't lose anything by accident. This is what I do to make a backup, so don't blame me if something goes wrong. LOL. After OBS is opened go to file - show settings folder - scroll down to basics - scenes. All the scenes will be listed - copy them to preferably a different drive, but I'm not entirely sure if it's a problem if they're on the same drive as OBS. Then just delete the files not the scene folder. It should be blank. You will open up to a brand new and clean OBS. You can start from scratch or try to bring back what you had backed up to see if that is the problem. As far as the blue screen in draw, I get that too, but I think I had found a way to work around it in the final mix.....I should also say, "I'm not a gamer, so I don't need for things to work in realtime. However, Exeldro listens and I'm sure he'll get to the bottom of this if enough people can help him identify the issue. You can also use his scene collections manager to back scenes up Best of luck!
Hi, thank you for this incredible plugin.
Are you going to implement hotkeys and a fullscreen option? I would be great to be able to clear the draw with a shortcut and use the module in fullscreen on a touch display.
Thanks. I'll give your suggestions a try.
When I try to download the installer version for windows the .zip file gets flagged as containing the "Wacatac.B!ml" trojan and promptly gets deleted by Windows Defender. The non-installer version works fine though!
@EdwardNottingham Windows defender does not flag the installer for me. Also Checked ViusTotal and that looks to be fine too.
Thank you for checking. I dug into it a little more, and it only happens when I download it with a Firefox variant called Waterfox. Regular Firefox is fine and so is Chrome. Obviously no fault of yours! I'm guessing Windows is being weird with my browser choice or I have a compromised extension.
I am having an issue with your draw plugin. Love it, but don't know if it is supposed to do this, but think maybe not. Draw from the dock opens automatically whenever I open OBS even after I uncheck it before closing. It will take up the full screen, so when I choose the full screen option it gets smaller. Perhaps this is because the dock is capable of being used on any source, but sometimes it's not needed. My suggestion would be to be able to close out of it like other windows or something to that effect . I'm using a Mac. Thanks.
