Cutting off audio source early
CPDeMaris
I don't stream. I record narrated gameplay videos that I edit and upload to Youtube. I'm using Source Record to separate the files. The last few times I have recorded a session, I get done and drag the files into Premiere, and the feed with the webcam footage and the audio from the microphone is shorter. It just cuts off anywhere from 3-5 seconds before the gameplay finishes to sometimes up to 3 or 4 minutes. Then I have to play the gameplay and record another bit of narration to finish up and keep it current with the gameplay. Any reason it is doing this all of a sudden? This only started recently. Here's the log from the last recording.
I might have answered my own question. It seems that this happens when my hard drive is filling up. I always move finished projects to a NAS for storage and if I forget for a few days and my SSD starts to fill up, these kind of things start happening more often, so the key is to keep moving recordings to the NAS immediately and keep a few GB free on the SSD at all times.
1. Change the refresh rate on your Samsung monitor from 144 Hz to 120 or 60 Hz.
2. OBS is not running as Administrator. Because of this, OBS will not be able to Game Capture certain games, and it will not be able to request a higher GPU priority for itself -- which is the likely cause of the render lag you are currently experiencing. Run OBS as Administrator to help alleviate this problem.
3. Your GPU is maxed out and OBS can't render scenes and encode frames fast enough. Running a game without vertical sync or a frame rate limiter will frequently cause performance issues with OBS because your GPU will be maxed out. OBS requires a little GPU to render your scene.
Enable Vsync or set a reasonable frame rate limit (120, 60, 30) that your GPU can handle without hitting 100% usage.
If that's not enough you may also need to turn down some of the video quality options in the game. If you are experiencing issues in general while using OBS, your GPU may be overloaded for the settings you are trying to use.
Please check our guide for ideas why this may be happening, and steps you can take to correct it: GPU Overload Issues.
SSD maintenance on your rig is lacking. Keeping that drive with little to no available space will cause it to slow down & wear out far faster than it should.
Best Practices for SSD Longevity and Performance​
To ensure your SSD operates efficiently and lasts as long as possible, follow these essential practices:
Maintain Free Space​
  • Leave 10-30% Free: Keeping a portion of your SSD free helps maintain performance. As the drive fills up, it can slow down due to the way data is managed and written.
Enable TRIM Command​
  • TRIM Command: This command helps the operating system inform the SSD which blocks of data are no longer in use. Enabling TRIM can improve performance and longevity by allowing the SSD to manage unused data blocks more effectively.
Regular Firmware Updates​
  • Update Firmware: Keeping your SSD's firmware up to date can enhance performance and fix bugs. Check the manufacturer's website for the latest updates.
Monitor SSD Health​
  • Use Diagnostic Tools: Regularly check the health and status of your SSD using diagnostic software. This can help you catch potential issues early and maintain optimal performance.
Additional Tips​
  • Avoid Forced Shutdowns: Always shut down your device properly to prevent data corruption.
  • Backup Data Regularly: Regular backups protect your data in case of SSD failure.
  • Ensure Proper Cooling: Keep your SSD cool to prevent overheating, which can affect performance and lifespan.
By following these best practices, you can maximize both the performance and longevity of your SSD.
