Question / Help Black screen not working even after using two forum's guides
SpaceMars8
^ These two forum posts that I have seen around haven't fixed my problem for having a black screen.
I am on a laptop on windows 10 using a NVIDIA GTX Geforce 1050 TI graphics card if that helps
Try to follow the "Wiki - Laptop Troubleshooting | OBS" guide page (search Google for link).
If still won't work, go to Nvidia control panel and win10 advanced graphic settings and set obs and eventually your video source (if it's a program) to use high performance gpu (so not the integrated graphic).
leave enabled Chrome hardware acceleration.
leave enabled OBS browser hardware acceleration in advanced settings.
try this
I can only speak from the standpoint of being an Nvidia Geforce user and recently ran into this problem, for the second time in my life, while upgrading my graphics card and NONE of the other solutions worked.
Pull up the Nvidia Control Panel
- Manage 3D Settings
- Scroll down until you see "OpenGL rendering GPU"
-- If it says, "Auto select" (which is preferred by Nvidia)
--- Select a specific GPU and click APPLY. (If you have two GPUs- pick one)
In Chrome, go to chrome://settings/system and make sure "Use hardware acceleration when available" is enabled.
Hopefully, this will work for you!
From Win10 1903 and onward, this will not work. You have to set the GPU affinity through Windows, not the nVidia Control Panel, as Microsoft forcibly changed it.
On the prior post from Drocky, disabling your primary GPU to forcibly set the affinity is like buying a new car because the gas tank on your current one is empty. Don't do that. It's an awful idea all-around.
