atkAudio Plugin
atkAudio Plugin 0.33.1
Hello may we have a select all or select non for the channels. I have an interface with like a billion inputs and outputs so its a bit tedious to click one by one every time
Hello my input 1 on my interface is my mic and it is mono but when i try to input to the output 1 and 2 i can only hear it in my right ear.
However if i put input 1 to both obs output we can see that its outputting to both
The work around is to set input to go to 1 and 2 and set my output ch 1 to 1 and ch2 to 2
Ah, there's a bug. If you want to do inside PluginHost2, you can use this as a workaround.
https://github.com/atkAudio/PluginForObsRelease/releases/tag/0.31.6 you can also try this
Hello! This seems like a very cool and powerful plugin. However, I cannot get MIDI control to work at all with a Stream Deck.
I've installed the Stream Deck Midi plugin and loopMIDI and am attempting to use a simple dial control. I have two ports configured in loopMIDI named StreamDeck2Daw and Daw2StreamDeck, and the Stream Deck Midi plugin is configured to use StreamDeck2Daw as the midi out and Daw2StreamDeck as midi in. I drag a Generic Midi to a dial on a Stream Deck+, and leave it set to defaults, so: Command = CC, Control = 0, Channel = 1, Min/Max = 0/127, and settings for midi ports as described before. Inside a PluginHost2 filter I can add the Midi In plugin and set it to use StreamDeck2Daw as the in, and when I turn the dial on the Stream Deck+ it does work and I see the CC messages coming in. However, from there connecting the red output port to the red input port on other plugins (even the Gain plugin included with atkAudio) results in no midi messages being passed along. Thinking maybe I needed to configure some kind of passthrough I tried setting StreamDeck2Daw as an "output" (with it both also configured as input and not) on the Midi In, and no dice. I have made sure that the next plugins in the chain do have midi enabled and the channel/control values match. Ticking learn, even in the gain plugin, I never see anything learned when I adjust the knob.
I admit I am completely new to all of this and primarily wanted to use the atkAudio OBS plugin as a means of capturing ASIO audio and using midi to control various parameters from my Stream Deck. I feel like I'm possibly missing something super basic but I've no idea what... If anyone has any input on where my chain is likely to be misconfigured I'd appreciate it!
Okay, embarrassingly, I restarted the entire stack of software and the issue has resolved itself. As I keep tinkering with things I will try to pay explicit attention to what I did if I get stuck in this state again and report back if it's something related to this plugin.
Thanks!
Thanks!
Well, in anycase, sounds great! Good test is to route some MIDI into gain plugin, enable Learn, and see if gain plugin responds to any MIDI, e.g. moving a fader.
Using latest one still need to use gain plugin workaround if i want to hear mono microphone in both left and right if all the vsts are also mono. works fine if vsts are set to stereo
with the new versions after .31 I'm also having some instances of OBS completely crashing on scene switching specifically to scenes that have DeviceIO or pluginhost2 in them. I can't confirm or reproduce but want to put this on the radar as it's been happening fairly frequently on streams.
i have problem with some plugins the windows does not resize correctly and is hard to press button, pratically if. you search them in the black side, you can find them but is pretty hard, to some plugins like the Wave Breaker and YouLean it does go funky. Is possibile a Fix? Thank you!
Ok so 31.8 fixed the crashing on scene change but now if I use the replay function, switch to a scene with a replay and switch back to my main scene my audio is about 600ms out of sync and it slowly returns to being in sync over the period of 16 seconds or so. Pretty wild. Help?
it's because suddenly larger amount of audio data is being instantly flushed into filterchain for some reason, but e.g. deviceio still processes the buffer at realtime sample rate + slight speed up to maintain continuity while depleting excessive data from buffer in the audio signal.
Ok but this didn't seem to be an issue in previous versions. The issue is when I'm changing scenes back from a replay the audio in the main scene is out of sync for up to 20 seconds. How would these be resolved so the scene change would induce sync issues?
